Cooling Sys, Health Check, etc 20
, 02-07-2016 at 02:31 PM (2782 Views)
Keep cleaning.....
Before/After.
Removing the old red sealant from the oil cooler fixing thread.
The most time consuming task of replacing just the 2 coolant hoses at the oil cooler finished….
Cleaned the wheel speed sensor area at the RR corner…..
The sensor head had some scratch markings but seemed to be not too bad.
Finally, the thermostat cover, rad fan control sensor, etc arrived so I can finish the cooling system.
I was so excited with the delivery that I forgot to take the photo of the new thermostat behind there…. D'oh!
All coolant hoses replaced, new header tank and cap. Will carry out the vacuum leak check followed by the vacuum fill later.
Will adjust the TH cable free play later.
