Cooling Sys, Health Check, etc 08
, 29-05-2016 at 11:50 AM (2650 Views)
What this connector is doing here...... Interlock control unit???
Probably not used on early UK model???
Once again, having fun with the removal of drive shaft joint inside the hub.
Last time when I had big time, I broke my hydraulic puller so this time, I think I need to invest in the big daddy tool….
Busy weekend with so many things to do including one A/C CCU board that I have never seen so many damages done by someone who doesn’t know the wording ‘through hole plating’.
Basically, instead of de-soldering, this person decided to drill out the circuit board to remove the old solder….
Unbelievable….
Joy of dealing with the NSX that I have never serviced before....
Always find something wrong once start working on it....
Another delay but same for everyone so hope other owners in the queue can wait patiently.....
More to follow later after the race...… It's wet....
