Cooling Sys, Health Check, etc 05
, 29-05-2016 at 11:23 AM (3830 Views)
The FR wheel arch liner and the R condenser fan cover are gone.
Together with the big marking inside the wheel arch, huge tyre size was used in the past.
You can still see the trace of melted liner here.
Lots of hair line crack at many suspension bushes….
Same at the rear mount....
FL sway link is hitting the damper body. May not be the case once on the ground but may cause metal noise depending on the load condition.
Interesting BRAKE LAMP warning behaviour.
If you don’t engage the parking brake, seemed to be fine.
If you engage it, it will either trigger it or just show faint dark red indication….
After this, if you press the boot opener on the driver’s door, it will always trigger the warning….
Looks like multiple issues here.
Wiring somewhere back in the boot and also very likely to have caps leakage at the gauge assy….
