Cooling Sys, Health Check, etc 04
, 29-05-2016 at 11:14 AM (3109 Views)
Tail light assy showed crack at several places…
This lens for the rear fog light is rattling and no longer bonded. I can see inside of the tail light assy.
Water is entering the area freely….
Aftermarket radio antenna with so many extra wires…. I’m not going to touch it….
Yet, I may have to, as the ‘BRAKE LAMP’ warning light comes On if the parking brake was pulled up despite there was a wire to disable the warning (the light blue single extra wire).
Could be the gauge issue as well.
The smell of eng oil was terrible with blowby gas.
The PCV valve was clogged in black debris.
Will clean it using the carb cleaner and check its operation.
Front brake disc is dead… Not sure you can see the state from this 2D photo but it was just so bad....
Uneven wear with vinyl records like deep-deep-deep markings (yes, it was that bad....).
Hope I can get the long waiting Dixcel brake disc from Burns Motorsport this time.
This radiator was leaking in the past.
Because of the characteristic of the coolant, the leakage has stopped but please remember that the radiator is a consumable parts, just like the oil filter.
