Health Check, Brake OH, Koyo Rad, etc 07
, 05-10-2015 at 02:50 PM (6612 Views)
While waiting for the return of the callipers and brackets from Bigg Red, installed the front new disc.
This photo is for the FR side.
Top hat and the edge of the disc are nicely coated to prevent the rust.
It’s straight vane type with limited number of slot so the slot direction can be either way but I prefer following the standard direction and it’s also the same way as per the sticker on the new disc.
The owner uses different spec disc on the rear and the slot direction is different from the new disc at the front.
This photo is for the RR side.
When the time comes, the owner will install new rear disc with the same spec and slot direction as the front one.
Just make sure to remove the sticker before mounting the wheel.
While having the access, gave a good cleaning around the area…..
At the same time, cleaned the rad fan shroud.
Rinsed the new Koyo Racing radiator very well.
Briefly installed the rad fan on the Koyo Racing rad.
New rad installed on the car and ready for new coolant hoses.
