Bose Speaker AMP Service 02 - Done
, 23-04-2011 at 11:40 PM (2651 Views)
After servicing the two remaining Front AMPs, all three are ready to be tested on the bench.
As my standard procedure, each AMPs were aged/driven at least 2Hrs with reasonably high signal level to test them under heat.
Photo has been edited for security reason.
Happy with the result so they are now ready to be returned to the owner together with the A/C CCU board.
The owner wanted to collect them over the weekend from my place.
Unfortunatey, I already had several appointments and also need to be prepared for the arrival of another NSX during this holiday weekend so they will be returned through the post.
Thank you for using my service and hope to meeting you in the near future.
