Health Check, Alignment, Brake OH, etc 07
, 18-08-2015 at 10:54 AM (1987 Views)
New banjo bolt at all four corners.
When was the last time you replaced your brake fluid?
Lots and lots of black slimy debris from the seal and the aluminium cyl wall.
If you don't track your car, at least every 2 years please......
Pressure bleeding. Quicker and saves the fluid by bleeding from the front side if your NSX is equipped with the later spec ABS.
Considering the current mileage and re-using the brake pads, set the fluid level at this level for this NSX.
Time to put the wheels back on the car.
Hope to return this NSX this weekend depending on when I can book for the alignment service.
