Brake OH, etc 04
, 08-05-2015 at 06:35 PM (1732 Views)
Another tail light assy with moisture inside.
Two different plastic materials bonded together so over the years, it will warp at different rate. Left side was not too bad but quite big gap at the top on the right side assy.
Some owners think that the light assy is a shield unit but it’s not. There are many holes and slits behind the assy so air/debris/moisture can enter freely so not wise to drill even a small hole....
Aftermarket rear wing scratching against the right rear panel/wing. Not great fitting…..
There was no hunger at the left side of the aftermarket exh back box but probably done on purposely???
As always, the head light unit on the face lifted model is very close to the edge of the bumper. In fact at the right side, it was too close and hitting the bumper paint.
Some sort of aftermarket intake duct installed but not quite aligned….
