Eng Refresh + LMA, Bilstein Damper, etc 22
, 10-04-2015 at 10:35 AM (3506 Views)
Double check the tension. Some know-how here as well.
Replacement NTN bearing and the A/C idle pulley is so much quieter now.
The rubber seal at the TB tension adjuster bolt. Chances are, it's missing on your NSX......
With so many things to be done this week, I was too tired to go through the 4Hr marathon valve clearance adjustment so decided to just close the TB lower cover.
Of course, the expensive TB lower cover gasket replaced with the new one. Quite often, it's missing from the TB lower cover on many NSX......
Considering the weather forecast and the temperature, will do the valve clearance today as the temperature looked to be dropping significantly for Saturday with rain forecasted.
