Eng Refresh, Health Check, etc 14
, 22-01-2015 at 07:56 PM (2003 Views)
More liquid gasket and it's black.....
Even it was used at the outer surface of spark plug hole gasket.... Why??? If installed oil free, no need.
Fairly clean valve cover and internal engine parts.
Another reason why it is important to use your NSX frequently and change eng oil regularly.
This NSX is spending some time on track so high rpm used and the mileage is not what we call low, yet the compression data is good and very clean internal engine parts including back of the valve covers.
Hot engine oil will do very good job in cleaning the engine and also driving your NSX for a long journey at moderate rpm band is very good in getting rid of contaminated blowby mist.
