Eng Refresh, Health Check, etc 27
, 20-12-2014 at 01:33 PM (2400 Views)
New RR wheel speed sensor and installed. Applied silicone compound around the sensor body and hub carrier hole in order to prevent future oxidation.
The washer for the eng block bleeder joint. You don't need this if the bleeder plug was tightened at the right spec but if someone overtightened it in the past, you will need it as it will remove the joint all together.
Once again, spending time for cleaning...... Nice engine bay.....
As reported earlier, will re-install the fuel filter bracket as it was not installed properly.
Behind the schedule again but hope to put the engine back in place soon.
Keep working through the Christmas as I really want to book the flight....
