Annual Service, Health Check, Brake OH 21
, 17-09-2014 at 02:09 PM (2548 Views)
As seen on other NSX, the fixing screws were missing from the rear ceiling trim.
I will try to find the closest one from my spares.
Probably the same on your NSX....
The A/C CCU cabin temperature sensor aspirator fan was full of dust.
Disassembled and cleaned.
As seen on many areas inside the cabin of our NSX, the leather like surface trim started to dislocate itself from the glove box lid.
Similar thing is happening on other NSX around the area of the panel just above the driver's knee, the long boxed shape trim where
the fuel lid opener is located, etc.
The worst thing is that some sort of oil like material is coming out from the plastic panel underneath that
even you try to fix the issue, the issue will come back again later.
If I have extra time, I'll look into this but may leave it for the future as I have higher priority items to be done first.
The NSX-T roof locking mechanism.
Together with the ones at the roof side, you need to loosen these in order to adjust the alignment.
