Annual Service, Health Check, Brake OH 04
, 17-08-2014 at 12:38 PM (1831 Views)
The roof alignment is definitely not quite right. Almost like angled agaisnt the centre line of the chassis.
While the right side front pillar is lined up nicely to the roof section, left side is not so good so someone may have removed it in the past.
Still, no wind noise so quite surprised.
If I replace only a few parts and re-use rest of the items, you already know what will happen... Wind noise....
Some sort of helicopter tape at the edge of the NSX-T roof??? Also, bit too much butyl sealant used at the front section.
Seems like the gauge visor or the gauge itself was removed in the past. The gap at the right side was significantly larger than the left side.
