Annual Service, Health Check, Brake OH 03
, 17-08-2014 at 12:12 PM (1734 Views)
The alignment around the rear wing was not quite right.
Also the treatment after the welding may not be done enough???
Cable fixings for the radiator fan were dislocated. Luckily, they were still trapped around the cable itself so re-installed them.
The damaged very expensive NSX-T rear weatherstrip.
Was going to replace it but now that the owner brought all the receipt from the past, went through them and noticed that it was replaced in the past.
Not sure whether it was for the same reason or not but there is a chance that something specific to this chassis is causing this as it's very unusual to see this.
Will look into the window and roof alignment first before replacing it as I don't want to see this happening again.
