Annual Service, Health Check, Brake OH 07
, 12-08-2014 at 11:11 AM (2322 Views)
Once again, thank you to the continued support from Goodridge for providing their custom made brake lines based on our spec.
Please note that the ones that you can buy over the internet or from other vendors are not the same products.
Even it is in the Goodridge branded box, it is very likely to be assembled by the vendors themselves using the parts (including the box) purchased from Goodridge.
You may end up with wrong brake line length, missing line holder at the front, etc.
I only buy this through Goodridge Exeter office using NSXCB ordering code ZZMT-NSX or ZZMT-NSX-BK.
Please note that this is only available for UK delivery address.
Detail as follows;
http://www.nsxcb.co.uk/entry.php?340...ade-Brake-Line
As mentioned many times, lots of owners with aftermarket brake lines tend to be running their NSX with twisted line.
Not great and potentially dangerous.
Always mark the chassis and brake line to line them up preventing twisting during tightening the fitting.
Nicely done.
Moving onto the rear calipers and it's the same stroy.....
Looks like the pad and disc are OEM ones.
Time to bench bleed the master cyl.
Getting there....
