Annual Service, Health Check, iPod adaptor, etc 06
, 31-07-2014 at 10:26 AM (2448 Views)
Not much to report while placing everything back in place.
Quick check inside the cabin before placing the centre console back in place.
New OEM green air cleaner element installed.
Depending on the spec of ECU software, it will trigger CEL during the compression check.
Sometimes, it's related to the MDU and other times, it's the TH.
Also, you will need to start the engine with either the EACV disconnected (for non-DBW) or SCS terminal shorted (for DBW) on idle rpm check so it will trigger CEL as well.
Just reset the ECU and let it to re-learn all the co-efficient value under no load condition. Will carry out 70mph cruising mode to set all the emission flags later.
Back in place.
Quick check on A/C and also all the switches/lights on the centre console.
Just need to modify the centre arm rest glove box for routing the iPod adaptor.
Soon, it will be ready for the owner to collect this NSX.
