Final Touch
, 17-07-2014 at 09:37 PM (2333 Views)
After basic testing, back to the lift, general checking and happy with the result.
Although I didn't touch the engine this time, in order to push out any air bubbles inside the cooling system, went out for the final test driving session with continuous 70mph cruising for about 20min while keeping the CCU setting at 32degC. Not fun at all in this hot weather.
Back on the lift and as reported to the owner long time ago, the right side inner joint drive shaft is splashing the grease.
Let the car to cool down, washed the car, final check and confirmed that there was not a single air left at the heater core as well as at the top tank of the Koyo radiator.
Adjusted the coolant level and done.
Until the owner collects his NSX, it is on the battery conditioner.
