Eng Refresh 22
, 23-01-2014 at 11:48 AM (5126 Views)
New oil pan.
Looks so nice compared to the existing one.
The reason why it had to be replaced.
There was huge dent on it.
For some reason, very popular on UK based NSX.
Probably, people were just lifting the engine by placing the jack under the
oil pan without any attachments.
While it could be fine for normal street driving condition, you don't want to
drive your NSX with this level of dent at the oil pan when you are expecting
high rpm with high cornering G.
You only have total of 5L of eng oil and the oil pump is pushing out
68L at 6,000rpm so you want as much eng oil as possible under the
strainer yet most of the time, the dent is right on there.
Didn’t feel comfortable re-using all of the nuts and also some of the bolts so
replaced them with the new ones.
Torqued them in three rounds at the specific order.
Remember to apply the liquid gasket at the side of oil pump and
the crank side seal plate.
As mentioned many times, personally, the torque spec of 14Nm in the workshop manual
is wrong for this rubber material oil pan gasket.
Just set the torque wrench enough to slightly spread out the gasket when all of the
bolts and nuts were tightened in the final round.
Oil pan with new gasket installed and the front header, A/C compressor, etc
back in place.
Pretty much lower side of the engine was done.
I’m not going to put any eng oil until tomorrow in order to
cure the liquid gasket thoroughly around the oil pan.
Existing O2 sensor.
Noticeable difference between the Front one (left side) and the Rear one (right side)
so good idea to replace both of them at this stage even without any CEL.
From the number on the sensors, very likely to be the original ones from the factory.
For non-OBD2 cars, Bosch recommends replacing the O2 sensor every 60K miles
regardless of getting CEL or not unless you have the capability to analyze
the sin wave of O2 sensor output.
Finally, I can see the light at the end of the tunnel so hope to return this NSX
to the owner towards the end of next week.
