Eng Refresh 24
, 17-09-2013 at 10:17 PM (11941 Views)
After cleaning the inside of valve cover, always replace the
valve cover gasket, dust seal and IG coil hole seal as a set.
If you order the proper kit, it also contains the metal/rubber disc washers
that must be replaced every time when the fixing nuts were removed.
No time taking the photos while dealing with the liquid gasket so
just the end result.
Valve covers back in place and confirmed that
the TB front and rear mid covers were inserted into the recess of
the valve cover.
When this NSX arrived at my place, front valve cover was not installed properly
and there was a gap at the mid cover.
Even this engine was fairly clean, still one can make some improvements.
Before installing the eng/gbox back into the bay,
quickly dressed the engine as there are several places that are
difficult to access or apply the dressing liquid.
Beautiful....
