Brake OH, Cooling Sys, etc 16
by
, 02-10-2016 at 11:25 AM (1778 Views)
And the installation of the AS Motorsport silicone hose on Koyo Racing Rad.
Good clearance and really like that we can use the OEM hose band/cramp.
I don't like these jubilee clip type for prolonged usage unless it is designed for the specific purpose that
would result in high cost.
Thank you to Adnan at AS Motorsport for very quick response in supporting this NSX and the owner.
As always, no modification required for installing the rad fan shroud on the Koyo rad.
Bit of obstruction from the aftermarket parts but all hoses at the front compartment replaced.
Will deal with the water valve cable later once the CCU is back in place.
I hope the water valve motor operates fine once the CCU is refurbished….
It's time of the year for my boss flying out for Japan for a while so massively busy at the moment but
hope to get back to normal from tomorrow.
