View RSS Feed
Recent Blogs Posts
  1. Final Touch
    by , 17-07-2014 at 09:37 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Went out for the test driving session.
    After basic testing, back to the lift, general checking and happy with the result.
    Although I didn't touch the engine this time, in order to push out any air bubbles inside the cooling system, went out for the final test driving session with continuous 70mph cruising for about 20min while keeping the CCU setting at 32degC. Not fun at all in this hot weather.
    Back on the lift and as reported to the owner long time ago, ...
  2. R12 and R134a A/C
    by , 17-07-2014 at 12:01 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    I wrote this for a thread on NSX Prime but some of the info may become useful for some of the readers here so I'm going to cut and paste my post.
    Original post here.
    While it may look the same, there are several differences between the R12 and R134a evap assy.
    Because it looks identical and the fitting is the same, both type will fit on any NSX apart from the difference between the LHD and RHD so in order to distinguish the difference, Honda placed small
  3. Koyo Rad, Cooling Sys, Washer motor 04
    by , 17-07-2014 at 11:26 AM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Pretty much done with the service and just need to carry out the final test driving session and wash the car. Then the car is ready to be collected by the owner from tomorrow (Friday).
    Adjusted the alignment of the washer nozzle as one of the driver side was pointing too low.
    Updated 17-07-2014 at 12:34 PM by Kaz-kzukNA1
    Categories
    Cooling , Body
