The most time consuming ones at the oil cooler area. Just two hoses yet you will need to allow about 2Hrs for them. Removing the old red sealant from the bolt thread. Cleaned ...
Standard procedure for me to fill up the new oil filter with fresh eng oil on installation. Due to big dent at the oil pan, couldn't extract similar amount of old oil compared to other NSX. Burst of short cranking and then proper fire ...
Initially, I thought it would be best to return everything including the cables when returning the faulty iPod adaptor USA Spec PA11-HON. However, after talking to the owner, he would try getting only the replacement control box and keep the good cables so that I can install them this time. ...
Ideally, wanted to keep the right rear wheel off for the oil filter change but in order to check the damper/tyre clearance, re-fitted all four wheels and bounced the car on the flat dolly. Full droop then under 1G at RR wheel. The rubber ...
Nothing special here so just a quick report.... Eng oil and filter changed regardless of super low annual mileage. As mentioned many times, when the eng is stopped, some of the valves ...
