The noisy cabin temperature sensor. It was full of dust as reported earlier. Disassembled, adjusted and now it’s clean. ...
Updated 30-11-2013 at 01:05 PM by Kaz-kzukNA1
Temporarily installed my re-soldered one for a test and confirmed the FCU failure. The faint noise you can hear in the background after replacing the FCU is the aspirator fan at the cabin temperature sensor. As seen on many NSX, it was full of dust making this noise. ...
Updated 11-11-2013 at 02:33 PM by Kaz-kzukNA1
When this NSX arrived at my place, I struggled to start the engine when the engine/cabin were still hot so replaced the main relay with a new one. As reported earlier, there seemed to be a problem with the Fan ...
Updated 07-11-2013 at 10:16 AM by Kaz-kzukNA1
As I didn’t want to start removing the parts such as the coolant hoses, CL master/slave/hose, etc without having the confirmation from Japan on the parts availability, decided to work on the electronics parts over the past few days. You don’t want to remove the coolant hoses only to find that it is on back order for ...
