Some of the photo will look strange due to the way I copied them but hope you can get the idea. The new high pressure spec washer motor with the sealing grommet and connector cushion. Checked the washer tube and nozzle using the ...
Started to work on another NSX this week. The service menu is to replace the leaky radiator with all aluminium Koyo Rad, replace coolant hoses, etc. While the radiator is out of the way, I'll be looking at the dead washer motor as well. Also, will provide the owner with the parts required for overhauling the early spec brake caliper. Normally, I carry out the test driving session before start of the service to check the base line but I already knew ...
