NO TRIAL PERIOD. Further detail HERE
Introduction The Supplementary Restrain System (SRS) ECU suffers from ageing capacitors the same way as many other ECUs in the NSX. Two things makes it a special issue: The SRS is a safety device and a permanently lit warning light means failing the regular vehicle checks in most countries. Especially the first generation ECUs (cars with only a driver's Airbag) tend to fail by shorting an important MOS-FET inside the housing which complicates repairs. Diagnostic Due ...
Updated 21-02-2021 at 03:49 PM by Heineken
