View RSS Feed
Recent Blogs Posts
  1. Eng Refresh 30
    by , 17-05-2014 at 02:50 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Ear plugs in, connected the battery and dis-arm the security siren.
    As always, never over-tighten the cable terminal.
    If done properly, you should see some gap like this.
    After leaving the cooling system under vacuum for nearly
  2. Eng Refresh 29
    by , 17-05-2014 at 02:42 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Quick oil change in preparation for the fire up.
    As my standard procedure, fresh Mobil 1 in the oil filter but probably not required.
    Vacuum leak check of the cooling sys.
    There was super
